Team Losi: 4-Threaded-Rock-Crawler Dämpfer-/Federnset
  • Zitat
    Key Features
    Shock set features four hard-anodized aluminum threaded shock bodies with hard-anodized aluminum adjuster nuts
    Adjuster nuts feature an internal rubber o-ring to maintain their position under severe suspension articulation
    Shock set includes ultra smooth Ti-Nitride shock shafts, white shock springs, shock limiters and assembly hardware
    Overview
    Losi’s 4” Rock Crawling Shock Set is specially designed for use with 1/10-scale rock crawling vehicles. The shock set features four hard-anodized aluminum threaded shock bodies with hard-anodized aluminum adjuster nuts for easier adjustments while on the rocks. An internal rubber o-ring in the adjuster nuts enable the nuts to maintain their positions under severe suspension articulation. The shock set comes with ultra smooth Ti-Nitride shock shafts, white shock springs, shock limiters and assembly hardware - just add the Losi Silicone Shock Oil of your choice.
    Quelle: http://www.losi.com/Search/Default…y=LatestRelease
    Gruß Fabi
