Sers,
von HPI gibt es den Baja 5B nun auch endlich in der SS-Variante ![]()
Zitat
The 1/5th scale Baja 5B RWD desert racing buggy has been a huge success with RC fans, racers and journalists, and Baja owners have been extremely happy with the racing prowess, durability and qualities of the Baja 5B buggy. Now, HPI is proud to announce the Baja SS, a full-option Baja kit that you assemble yourself, loaded with tons of hop-ups that enhance the speed and power of the Baja 5B buggy, improve its durability even further, and provide totally sweet custom looks!The Baja SS follows the HPI innovation of upgraded ‘Super Sport’ models that feature kit versions of popular HPI RTR models, with additional option parts added to enhance the enjoyment of your kit. A long list of option parts is included with the SS version of the Baja 5B. As you build the kit, you add in the options that come in the box, and add your own radio gear (receiver, throttle Servo, and receiver battery).
At the heart of the Baja SS is the #15403 Fuelie 26S 26cc engine, a tougher, stronger and more powerful engine than the standard 23cc Fuelie engine in the Baja 5B RTR buggy. With more displacement you get increased low-end grunt, more acceleration and huge top-end speed! The Fuelie 26S is a 2-stroke engine powered by regular pump petrol that is mixed with 2-stroke engine oil, so the running cost of the engine is extremely low when compared to any normal nitromethane-powered glow engine. You’ll spend just pennies per tank on fuel!
To handle the extra horsepower of the Fuelie 26S, the drivetrain of the Baja SS is boosted with specially designed option parts that can handle the power increase. Providing a boost of extra power is the #86690 Aluminium Tuned Pipe, which is designed just for the 26cc engine and gives even more acceleration power to the Baja SS. The #15448 8000 RPM Clutch lets the engine rev up to a high RPM before engaging the drivetrain, giving you lightning-fast acceleration off the starting line and out of every corner. Protecting the differential is the #87568 Aluminium Alloy Diff Case, giving protection from the extreme strength of the engine. Finally, the #86610 Heavy Duty Rear Dogbones get the power from the diff to the rear wheels with chunky steel driveshafts and jointed rubber boots for minimal loss of power.
Die technische Daten:
• Overall Length: 32 in (817mm)
• Height: 10 in (255mm)
• Width: Front 18 in (460mm) / Rear 19 in (480mm)
• Tire Track: Front 15.5 in (395mm) / Rear 15.75 in (400mm)
• Wheelbase: 22.5 in (570mm)
• Ride height: 3 in (76mm)
• Weight: 21.3lb (with radio)
• Camber: Adjustable front with shims rear with screw
• Front caster: Adjustable with shim 22 / 25.5* / 29 degrees (* stock)
• Toe-in: Adjustable front with tie rod rear with shims
• Aircraft aluminum 6061 T6 monocoque Chassis
• Double wishbone suspension with adjustable roll center F/R
• Twin plate ventilated disk brake
• Drive system: HD metal gears with sealed gear box
• Diff: Viscous Torque control with 4 pinion gears sealed diff cases
• VVC/HD shock absorbers and fully adjustable coil over springs
• Wheel type: 3 pcs with high impact nylon material Engine
• 2 cycle piston valve gasoline engine
• Cooling system: Air cooled
• Displacement: 26cc
• Fuel: Pre-mixed fuel, 25:1 (Gasoline:High grade 2 cycle engine oil)
• Starter: Recoil Starter Radio
• Transmitter, receiver, throttle Servo, receiver battery not included
• Steering servo: Hi torque, water resistant, metal gears
Weitere Bilder und Daten gibt´s hier:
HPI Europ: Baja 5B SS
MfG Jonas
