Precision CNC Machined TMAXX Fuel Tank with a micro polished finish. The top of the tank has a real Carbon Fiber accent cover and a fuel level tube that shows fuel from complete full down to the last drop. This aluminum tank works with EZ Start. USA Made... Awesome looking !! . . .very light weight . . . And immediate shipping ! !
Traxxas TMAXX: TRX 2.5, 2.5R Racing Engines, T-Maxx 3.3
BD Part No.: Aluminum Fuel Tank, (AL-4948M) Replacement or retrofit for the OEM Nylon Tank
Product Description: These Fuel Tanks are custom designed and manufactured by Billet Designs from light weight 6061 aluminum alloy.
They are a direct replacement for the plastic OEM TMaxx and is compatible with the EZ Start unit.
SPECS: Length: 68 mm, Width: 62 mm, Height: 78mm, Capacity: 170cc (5.75 oz)
Carbon Fiber: Hexcel (Carbon Fiber) 2x2 twill weave, laminated with a high grade epoxy and oven cured. Laser cut to fit the fuel cover profile perfectly. Mirror surface, thin and lightweight.
Items Supplied: Stainless steel hardware and all seals and gaskets are nitro fuel compatible. Packaged complete with all necessary hardware to use the tank within minutes.
Street Price: $55.00
Quelle: billetdesigns.com
Gruß Fabi
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von „FabiGD“ ()
